Network Analyzer
Hellow!
Anyone has the experience on how to measure the resonator parameter by a network analyzer?
thanks!
(3,419 Views)
Happybird,
I don't quite comprehend "resonator parameter".
Typically, I would be using network analyzers to do S-parameters analysis on a broad range of devices, and from there I can perform numerous evaluation (i.e gain, frequency check, linearity and etc).
In effort to fully utilise a network analyzer, you have to know what functions/options are provided and how do we call/configure them. Probably you can narrow down the model of the network analyzer. If I am familiar with it, I could probably provides more information to help you out.
Cheers,
JL Chew
(3,409 Views)
Hi! JL Chew:
Thanks for you reply, The reason why i use network analyzer is that i need to know the impedence-frequency response for the resonator( a crystal disk which can vibrate when electrically excited). So when i use network analyzer to do a sweep frequency measurement, Is the Y-axis the impedence? how can i get the admittance-frequency response?
Mike
(3,405 Views)
Mike,
If you are using Agilent E5071B ENA, there seem to be a function that does the parameter conversion. Refering to its user manual at Page 53, 226, 471 & 547, you are able to select the analysis for reflection impedance, transmission impedance, reflection admittance and transmission admittance.
I don't personally use other types of Network Analyzers and I haven't really use this feature before.
I hope these helps you out.
Cheers,
JL Chew
(3,398 Views)
