multiple color plot in waveform charts
Hi All,
I am plotting a chart. Now, depending upon some selection (say a number) the color of that particular region should change.
For example, if I take a typical logarithmic waveform, the linear portion of the waveform should have a different color and the saturation portion should have different waveform.
Thanks a lot.
Sreedhar
(4,491 Views)
sorry the last sentance of my question was wrong:
it should be:
For example, if I take a typical logarithmic waveform, the linear portion of the waveform should have one color and the saturation portion should have different color.
thanks and regards
sreedhar
(4,483 Views)
Hi
Just an idea - you could use an XY-graph and split one waveform plot up to three XY-plots. These can be assigned different colours.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(4,478 Views)
Actually it will be more helpful, if you can send some code. I am still a newbie
sreedhar
(4,472 Views)
Hi
I attached a simple example. Just have a look at it.
If you want, you could replace the subvi "ExtractSubset". There exists a similar function in the waveform palette, which gives you a certain subset of a waveform. Just have a try on this topic.
If you have any question about it, don't hesitate to ask.
Using LV8.0
(4,462 Views)
