Network Devices - Reserved / Unreserved
I have two cDAQ-9185 chasses in my system, and every time I restart the computer, the modules are not recognized (with the "Red x symbol"), as seen in the picture. Although the Chasse status will be (Connected - Running), I must unreserve and then re-reserve the network device to have it recognized again.
Why is this happening? How to resolve it.
(2,234 Views)
You can Reserving an Ethernet Based cDAQ Chassis from LabVIEW programatically.
https://tmesystems.net/
(2,179 Views)
Thank you.
But why this is happing ? previously it was reserved automatically, no need to open NI MAX each time and reserve it again.
When I changed the PC (HOST), this issue started occurring.. also the programmatically method is not suitable for my case, is there any other method to do it ?
(2,147 Views)
