Network variable can not read
I have created a network variable on the PXI and want to read the value from another PC, but it does not work. Anyone know the reason and how to solve this problem?
Best regard
CLAD Certificated
(3,911 Views)
Hi LLX,
"it doesn't work" isn't a good error description! Mind to tell us more details?
There are a lot of problems possible problems regarding network communication…
(3,895 Views)
Accepted by TUDarmstadtLLX
thanks for your reply. "It does not work" means: when I put the network shared variable in the while loop, it does not update the data when the value in the PXI changes.
Just now I have found the reasons, because I have not choose the right option. I mark it with red colour in the attached picture
Best regard
(3,891 Views)
Complete shots in the dark here:
IP Address issues
Firewall
You are not publishing the variable
(3,889 Views)
Hello.
yes, for my problem, it is the IP address issues.
Best regard
(3,883 Views)
