Network variable can not read
I have created a network variable on the PXI and want to read the value from another PC, but it does not work. Anyone know the reason and how to solve this problem?
Best regard
CLAD Certificated
(3,901 Views)
Hi LLX,
"it doesn't work" isn't a good error description! Mind to tell us more details?
There are a lot of problems possible problems regarding network communication…
(3,885 Views)
Accepted by topic author TUDarmstadtLLX
thanks for your reply. "It does not work" means: when I put the network shared variable in the while loop, it does not update the data when the value in the PXI changes.
Just now I have found the reasons, because I have not choose the right option. I mark it with red colour in the attached picture
Best regard
(3,881 Views)
Complete shots in the dark here:
IP Address issues
Firewall
You are not publishing the variable
(3,879 Views)
Hello.
yes, for my problem, it is the IP address issues.
Best regard
(3,873 Views)
