New to LabVIEW - need a simple VI that will turn a light on/off every 12 hours
Can anyone help me to design a very simple VI that will turn a light (LED) on/off every 12 hours.  I am unsure of how to use the timers properly.  I am outputting to a Measurement Computing Minilab 1008.  I understand that this will be extrememly simple to people experienced with this software but I need this for my project as soon as possible so any help would be much appreciated.
(5,010 Views)
Or anyone who can point me in the right direction, ie: examples
Any help would be great
(4,997 Views)
There's a variety of ways you can do this. You didn't say which version of LabVIEW you're using, but if you have LV 7 or later, you can use the Timed Loop structure. Plop it on the block diagram, double-click it to open the configuration window and set the period to the corresponding number of milliseconds for your time interval. If you have an earlier verison of LabVIEW you can use a while loop and the Get Date/Time in Seconds function. Sort of like the attached figure. Not that sophisticated, but you did say simple.
(4,986 Views)
Here is another one (LV 7.1), almost the same as the previous post.
Lynn
(4,980 Views)
If you are interested in a timed loop, this is what it would look like.
(4,969 Views)
Thanks for the help.  The less sophisticated the better, needs to be simple for me!!
Thanks again
(4,968 Views)
