New to Labview and trying to solve 50103 Errors
I am new to labview and have looked at so many threads to figure out how to solve my problem with resource conflicts.  Can you take a look and help?
Thank you!
Message 1 of 8
(1,980 Views)
Sorry here is the attachment
Message 2 of 8
(1,978 Views)
Error 50103: The specified resource is reserved.
I'm left to assume you are using a cDAQ chassis here.  If so, you can combine all of your analog channels into a single task (chain the DAQmx Create Channel VIs before the loop).  You can then read then all in a single read and use Index Array to pull out the readings for your indicators.
Message 3 of 8
(1,969 Views)
Thank you, I will give that a shot and yes I am using the cDAQ.  Do you combine only inputs? Or do you combine the outputs as well?
I will report back!
Message 4 of 8
(1,958 Views)
So I thought I knew what to do to chain them together by creating a common task and linking them.  That was much worst.  Can you explain with more detail how to combine or "chain" the Create Channel.
Thank you...
Message 5 of 8
(1,924 Views)
Thank you...
See Easily Synchronize and Trigger NI-DAQmx with Channel Expansion
https://tmesystems.net/
Message 6 of 8
(1,915 Views)
Thank you for the input, is it possible to break the array signal after you read it to display the two different inputs on separate gauges?
Message 7 of 8
(1,901 Views)
You can use the Index Array function. I would recommend you spend some time exploring the palette.
Message 8 of 8
(1,898 Views)
