04-25-2018 01:10 AM - edited 04-25-2018 01:14 AM
Hi All .
I am new to LabVIEW and have done a basic course however I have some issue with Arrays,Please help me understand this.
I am building an array with 10 elements (0-9) which gets populated with u8 data (for a CAN message Data)
this array gets send over USB to the CAN HW .this all works perfectly when each element does not contain a 0(zero) value ,
The problem is that once there is an 0 in a element all the Elements after the one containing the 0(zero) is not updated or populate with the new data,
as can be seen from the prints below .
my question how to force the array to always use and populate all elements or how is this handled in LabVIEW .
Here is the array when all elements are non zero
The data received and send correctly by the CAN message(in Hex)
Once there is a 0 in an element all elements after the 0 never gets updates the
The array building just for testing my error
I appreciate any help or information
Kind Regards
QMESAR
Solved! Go to Solution.
04-25-2018 01:33 AM
Hi qmesar,
This looks like a problem of the "USB Transfer" subVI or the hardware you use: the array is built correctly in your "main" VI…
As you don't supply any information for both items we cannot help you with detailed explanations!
04-25-2018 01:46 AM
Dear GerdW.
Thank you very much for your answer,I appreciate this.
I expected the supplied Vi from the HW manufacturer I will inform them and see if they can help with the sub VI,as for the HW I am 99% sure it is working correctly as using my own firmware in C on the unit CAN is doing all as expected.
Kind Regards
QMESAR
04-25-2018 02:33 AM
Could it be a case of the USB transfer assuming 0-terminated array, like a C-style string? Does 0 require some special handling? In some systems e.g. 0 could be a special character sign require some transformation (though you'd think the USB Transfer should handle that).
/Y
04-25-2018 03:13 AM
Hi Yamaeda
Thank you for your comments .
I would think the USB handle the array as it is bytes in U8 however I have no contacted the supplier I was afraid it me doing something stupid in LabVIEW and wanted to make sure with you guys first ,I will report back once I have more information
Kind Regards
QMESAR
05-04-2018 10:46 AM
Hi All
Just to report back on this topic,
As you all mentioned I handle the Array correctly the supplier has fixed a bug in the supplied dll and sub Vi for the USB Transfer
all is working fine now
Thank once again for all the help
Regards
QMESAR
