Newbie - How to have two states update the same indicator?
I have an indicator one my VI panel. I am using a state machine design pattern. I want data from two mutually exclusive states to be able to populate the indicator with data so the state updates the indicator. How is that done?
(1,479 Views)
You can use a local variable.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
Learn LabVIEW
(1,476 Views)
Thank you. I should have explicitly mentioned that this is NXG.
No local variables in NXG but only in LabVIEW. I found what you have to do is right button click on an indicator and select "Create Duplicate Terminal". Apparently a duplicate terminal in NXG is like a local variable in LabVIEW.
I have worked through most of the NXG training online videos. Do you feel the LabVIEW training would still be useful?
(1,460 Views)
You can also keep the value in a shift register and update it outside the case structure. Wire it across in statesthat don't update it and modify it in the other states.
(1,448 Views)
