Newbie graph question.
Hello there. My LabVIEW program is reading measurements from a digital multimeter. I need to make a graphic of that measure in terms of a current i manually vary. I would like to know if with an XY Graph can I plot this results. This would mean that X is my current and Y is the measurement from the dmm. Thank you.
(3,230 Views)
See here.
I would suggest reading up on graphs in the LabVIEW manual, going though the LabVIEW tutorial, and looking at the examples. Your question is answered in all three places.
(3,226 Views)
Hi there. I've seen this context help screen before but I didn't know where to find these array functions and how to manipulate them. I looked for them in the array palette but I didn't found  them.
(3,211 Views)
The top one is a Bundle function. It creates clusters from any type of input. The bottom is a Build Array function. It creates an array from the same type of element. These are both explained in the LabVIEW help. The top method is used when you want a single XY Graph. In this case you wire in an array of X values and an array of Y values to get a cluster of two arrays. The bottom method is used when you need multiple XY curves on the same graph. In this case you get an array of clusters.
I would strongly recommend that you go though the LabVIEW tutorial. As I indicated, there's examples that ship with LabVIEW that show the various graphs.
(3,201 Views)
