How can I create a Percent Fill Bar/Tank/Indicator?
Hi everyone!
Let's say I have three numbers. 30, 20, and 50. Is there a way to create an indicator that will convert this to seperate percentages and sort it so it looks sort of like a pie graph but horizontal/vertical (like the tank). I tried using the tank but Adding serpeate sliders , the data covers each other. Based on the given example, the 30 should be 3/10, 20 should be 2/10 and the 50 should be 5/10 of the whole tank. I hope you guys get what I mean.
(3,234 Views)
The easiest way is to simply add the sum of the previous sliders to the current slider as show in the attached simple example. Modify as needed.
(3,225 Views)
How about a barchart where each bar is a different color? If that would work, I can post code to do it...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,220 Views)
Ahhh... Now I see what he meant. Sort of a stacked bar chart - with only one bar.
Mike...
LabVIEW Champion
(3,216 Views)
