Newbie to LV run-time engine
I'm trying to open two .llb files for calculations. I downloaded the LV run-time engine, but I do not understand how it works. All that I am able to open is a data socket server. How can I use it to open these files?
Thanks in advance.
Message 1 of 22
(4,001 Views)
You can't open an llb or a VI with just the run-time engine. The rte is used when you create an executable from a VI. In order to open and run a VI, you need the development system. You can download an evaluation copy of that from NI.
Message 2 of 22
(3,989 Views)
Thanks for the help. Unfortunately my files were created with 6.0 and I can only find 7.0/7.1 on the website. Is there a work around for this, or a place to download the older version?
Message 3 of 22
(3,974 Views)
A newer version of LabVIEW can open old version VIs. If you download the 7.x evaluation version, you can open and edit 6.0 files with no problem.
Message 4 of 22
(3,970 Views)
Every time I try to open my files I get an error message :
LabVIEW load error code 11:VI version (6.0) cannot be converted to the current LabVIEW version (7.0) because it has no block diagram.
Message 5 of 22
(3,966 Views)
Ouch!
That was the only thing that could have caused problems!
Post your VI's and maybe someone will convert them for you.
Ben
Message 6 of 22
(3,964 Views)
Well actually, with the BD's they cannot be converted.
Hmmm,
Only an old version of the RT can help now.
Ben
Message 7 of 22
(3,961 Views)
Hmm, is this older version available for download anywhere?
Message 8 of 22
(3,960 Views)
This link looks like it is still alive. Try it.
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/d5f11a64a905db27862569ec005e31e2?OpenDocument
Note:
LV 6.0 was buggy.
LV 6.0.2 was great!
Ben
Message 9 of 22
(3,954 Views)
OK, I've downloaded and run the lvrt.msi file, but I'm still having the same luck. I guess I don't understand how the run-time engine and eval software work together. Do they have to be in the same directory to interact?
Message 10 of 22
(3,953 Views)
