Newbie to LV run-time engine
@Jean-Pierre Drolet wrote:
With the Run-Time Engine, you also need an executable build with with Application Builder from LV6. I work like this for our company internal projecst and even for some customers that keep the source code. People have the Run-Time Engine installed and a little build application to open and run VIs. It avoids to build and rebuild applications for every project/version I just need to distribute VIs (with diagrams usually).
Your coworker basically let you on your own if he didn't tell you where to get the LV6 RTE and an application that could run the LLBs. LV7 RTE will be useless
OK, someone else has seen this work.
I no longer have 6.0 so I can not build an exe for you.
I once saw my co-worker just open and build (using all defaults) an empty exe.
Once built and run, it presented a dialog box looking for a VI to run.
He was able to navigte into vi.llb and ran one of the Express VI's.
So...
If someone is listening that still has 6.0, then they may be willing to do the empty build thing.
Ben
Message 21 of 22
(639 Views)
Thanks for all the help, though I'm still stuck unable to open these files. If anyone can build an empty 6.0 executable it sounds like that would help.
Message 22 of 22
(630 Views)
