Newport/Klinger MotionMaster 2000 (MM2000) Driver
Hello.  Has anyone had any experience with the Newport/Klinger MM2000 (MotionMaster 2000) system?  I am a gradute student that recently inherited a system that contained the interface box, connection cable, and an ISA system board.  I am trying to acquire the procedure to have the ISA board be recognized by Windows and configurd by LabView.  Does anyone have access to an installation disk that will allow this to take place?
Thank you
Doug Slusark
dslusark@rci.rutgers.edu
(4,022 Views)
Howdy Doug,
We have a Plug and Play driver to use your MM2000 system available from our Instrument Driver Network.  You can refer to the installation instructions or How to Use an Instrument Driver in LabVIEW if you have any questions on installation.  The MM2000 driver is unsupported by NI, which means you'll have to use it "as is".  However, if you have specific questions on how to use the VI's, you can definitely post to the forums.  Good luck!
Sincerely,
Chris G in AE
(4,007 Views)
