Newport YAG Laser power supply serial control
I just noticed on the example program, the baud rate is supposed to be 4800 (not 9600), and yes, 2 stop bits
Message 11 of 28
(1,909 Views)
Good point about the EOL.
Message 12 of 28
(1,909 Views)
I sent this reply, but it didn't show up for some reason...
Good point about the EOL constant...
I also noticed from the example in the .pdf, the baud rate should be 4800 not 9600, and b) # of stop bits IS 2
Attached is an updated vi
Message 13 of 28
(1,891 Views)
I sent this reply eariler this morning but it has yet to show up, so I will try again.
Good point aboit the EOL constant!
I also noticed a) the baud rate should be 4800 not 9600, b) and the number of stop bits IS 2.
Message 14 of 28
(1,891 Views)
Not yet shown up where? The original replies have been there since this morning. Are you viewing the board through a newsreader, or through some other interface?
Message 15 of 28
(1,890 Views)
Doh!  I didn't get the e-mail response from NI nor did I see it now has 2 pages.
Sorry for the confusion
Message 16 of 28
(1,887 Views)
Hi again,
Thanks for the program! I really appreciate your help here, and it's good to see how these VI's should be written.
I tried out the VI, but it didn't turn on the laser. I'm not really done pursuing all the paths here, I need to tinker with this some more, the answer might be less of a labview issue.
Just wanted to thank you guys for all the help!
Karl
Message 17 of 28
(1,864 Views)
Karl:
Does the laser or the supply have a hard-wired safety interlock that needs to be closed in order for the laser to fire?
Message 18 of 28
(1,851 Views)
Maybe the commas don't belong but are acutally command delimiters and should be replaced with carriage return\linefeed, but I really don't know.
AnalogKid has a good point...maybe there is a hardware-interlock preventing it from turning on.
Try some simple sequence of commands and see what happens (maybe read a status of some sort).  I don't like communicating with an instrument or ECU that doesn't talk back; try a VISA-read just before you close the reference to see if it is responding.
Is the manual on-line somewhere?  That would help us diagnose the problem.
Glad to help...where are you located?  It would be funny if you were around the crner from me (Farmington HIlls, MI).
Message 19 of 28
(1,847 Views)
That's something I'm wondering about:
The laser does have an interlock, so before running the program I close the interlock, and turn the switch on the front. If I wanted to turn it on manually, at this point I would press the switch on the front of the power supply. Instead, I flip the control switch from local to computer, and run my program. It seems like there are a lot of options here: do I turn the key on the front, or not? Obviously (I think) the interlock has to be closed.
Right now I'm just trying to run this from a computer that is right there, but soon we will want to control it from a separate room. I don't have much experience with lasers and interlock systems.
Message 20 of 28
(1,846 Views)
