Next and previous buttons, Cluster, Image Ring problem
Hello, I'm a pretty new user, and I need help with this excercise:
"Create an application in LabVIEW to manage the information of different cars from the movie Fast and Furious. The goal is to show in a Graphic User Interface the information of the cars included in the following table:
ID
Name
Model
Brand
Price
1
Eclipse
2000
Mitsubishi
$ 25,550.89
2 RX-7 2010 Mazda $ 32,700.50
3
Supra
2000
Toyota
$ 39,450.30
4 Charger 2012 Dodge $ 45,290.99
5
Civic
2013
Honda
$ 27,600.40
6 S2000 2006 Honda $ 29,500.99
7
Jetta
2013
Volkswagen
$ 21,740.90
The type of data that should be shown in each field is presented in the following list:
  •   IDInteger
  •   NameString
  •   ModelInteger
  •   BrandString
  •   Price Float
    Write a program that shows the information of every car included in the table. file Fast_Furious.vi as a starting point to write your code.
    Specifications
    The following image shows an example of the User Interface of the program:
You can download the
The user should see the information of 7 different cars using the buttons Next and Previous. Each time the user press these buttons the information of the previous or next car should be presented on the interface. There are two special cases in the selection of information:
  •   If the information of the first car (Eclipse) is shown and the user makes clic over the button Previous. The information of the last car (Jetta) must be shown.
  •   If the information of the last car (Jetta) is shown and the user makes clic over the button Next. The information of the first car (Eclipse) must be shown.
You must use the array of clusters to obtain and manage the information of the cars, and the ring to show the photos of the cars.
Finally, include a close button to stop the execution of the program.
Extra: Add sound effects to your program. Each time the user makes click over the Previous or Next
button a beep sound should be produced."
I especially need help with the next and previous buttons and the sounds. I alredy have all the information, and the app is supposed to look like the picture attached.
(2,982 Views)
Hello Miguel,
Are you searching for part time LabVIEW programmer to do this job for you or do you want to do it by yourself?
If you want Part time programmer, please post your requirement in “LabVIEW Job openings” .
If you want to do you it by yourself, Please post your code & ask for your issues. Only GUI will not help.
Munna
(2,942 Views)
Actually, Munna I think I smell a homework project (2nd year of college, maybe?)
So Miguel, what have you got done so far? What does your code look look like?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,883 Views)
