Ni-DAQmx LabView examples won't work
Oh, haha, that makes sense... the -2 to 2 V.  Oops!
I understand adding 2 will give me 0 to 4, but I need 5 V for my physical circuit that i'm hooking up to the USB-6009 to work.  How were you able to see what was inside the array (aside from plotting it - I got that, thanksSmiley Happy)?  If there is a way to see inside it, perhaps I can recreate one for my own purposes, or alter the given one for my needs?
Thanks so much!
Message 11 of 13
(905 Views)
Muwahahahahaha....  for right now I've got it adding by 2, and then multiplying by zero or 1.25 (to get 5V) depending on which way I toggle the switch I inserted.  Not necessarily the best if you look at the block diagram, but it works until I can figure out how to mess with that array.
Thanks you so much for all of your help.  You've really saved me, and I understand this all a little bit better Smiley Very Happy
If you have any tips for the array, that'd be great.  If not, just take my sincere thanks!
Message 12 of 13
(895 Views)
You're welcome, one little tip look at the signel generation palette:
You can also try searching this site and google for LabVIEW tutorials. Here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
Ton
Message Edited by TonP on 03-03-2007 01:11 PM
My LabVIEW Ideas
Message 13 of 13
(873 Views)
