Ni-DAQmx will not install
i am having problems installing NI-DAQmx 8.0.
from the menu i choose "Install NI-DAQmx/VI Logger"
at the next screen with form label "NI-DAQmx 8.0" the following message appears;
"Please wait while the installer initializes"
at the first green block on the progress bar a message box pops up with the label
"setup.exe"
"The instruction at "0x%08|x" referenced memory at "0x%08|x". The memory could not be "%s"."
the only option is to click OK and exit to desktop.
some background:
this software has been previously installed on the computer and ran with no problems.
it had not been run for a few weeks & when i went to run, it the Measurement & Automation Explorer
ran alright but nothing was detected under  "Devices &  Interfaces", not even the sub folder called
"NI-DAQmx Devices"
when i tried to uninstall the software it got around half way  then  stopped.
all subsequent attempts to uninstall/install failed.
i have run Registry Mechanic which fixed up alot of missing links etc errors and have manually deleted
all files that are obvious NI
i have run Windows Install Cleanup which fixed problems associated with .msi installer.
i have installed software on another computer & tested hardware - all with no problems.
i suspect that there is a corrupt registry entry or corrupt .dll files lurking somewhere
any help in fixing this problem would be greatly appreciated
(2,700 Views)
Hello Andrewke,
This type of problem could be better handled by phone or email support.  If you are still having problems, please visit www.ni.com/support to create a phone or email service request.  If you create an email service request please reference this discussion forum posting.
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
(2,684 Views)
