Ni-OperatorInterface - Read/Set TestStand-StationGlobals via SequenceContext
i´m using the default NI-OperatorInterface (with some modifications) which is located in the TestStand-Directory in C:\Programme\National Instruments\TestStand 3.5\OperatorInterfaces\NI\Simple\LabVIEW.
My problemis that i dont know how to get a "sequence-context" in here so that i can read and set the TestStand-StationGlobals.
I want to add an event-case "value change" in the attached screnshot so that i can press a new button in the OP that is recogniced by the event, and then this state should be written to the StationGlobals. But i have no sequenceContext to execute the "Set Property Value.vi"
When i check the properties of the ExecutionView Manager then there is a sequence-context, but when i use it, then its not working. (see attched screenshot)
TFTC
Message Edited by OnlyOne on 08-09-2007 04:57 AM
(2,536 Views)
You don't need Sequence Context.  With Application Manager, you can get TestStand Engine, from Engine, you can get Station Globle.
BTW, you should post to TestStand forum.
George Zou
George Zou
(2,525 Views)
