No COM ports available in the Measurement and Automation Explorer
Hello everyone,
I have installed Labview version 9.0 (32-bit version) on a Windows XP machine with the Measurement & Automation Explorer. When I open this, the program cannot find any COM ports or LPT ports. Does anyone have a solution on what to do?
(4,081 Views)
Assume your system has all these ports.
Try this option, goto MAX, Devices and Interfaces--> Serial& Parallel-->Right click on that and create new port.
Hope this works for you
(4,067 Views)
Have you installed NI-VISA from the device driver CD/DVD?  It should be installed automatically.
(4,063 Views)
I don't even see Devices and Interfaces. All I see in the Tree View is My System and Remote System (which has nothing in it). Under My System is Labview 2009, Labview 9.0 Run-Time, Labview RunTime 8.2.1, LabWindows/CVI Run-Time 9.0, Measurement and Automation Explorer 4.6, and NI-USI 1.7
Sorry, I'm a newbie at this.
(4,060 Views)
Accepted by topic author BadAzzS10
Put in your device driver CD/DVD and install the device drivers again.
(4,050 Views)
I would also suggest the same, try re-installing the device drivers
(4,042 Views)
