No Errors, but VI will not execute
Accepted by lxjx
That helps a lot.  One of the polymorphic subVI's is broken.  If you want to find out which one, try taking a copy of the Create Channel DAQmx VI and drop it in a new VI.  Use the drop down to pick a different instance and keep doing that until you come across one that definitely causes the run arrow to break.  (No guarantees that this will show it, but seems like a good idea to me.)
Ultimately, I'd recommend you try reinstalling your DAQmx device drivers.
Message 21 of 24
(963 Views)
I re-installed the DAQmx driver.  The vi works again.
Message 22 of 24
(932 Views)
Its not too uncommon-  A lot of the vi's in vi.llb and in the DAQ palattes can get saved over by developers that are not being careful about what caahanges they save when looking into vi's they should leave alone.
A good practice is to make the shipping examples and vi.lib read-only. (and options> envionmental > "treat read only vi's as locked" + "do not automatically save")  It will keep you sane in the futureSmiley Wink
Message 23 of 24
(919 Views)
Thanks for the pointer Jeff.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 24 of 24
(904 Views)
