Noise from Strain Gauge Reading
Hi, I am trying to get some data from a strain gauge using a quarter bridge setup through NI 9235. I am getting this noise shown in the attached picture. Is it something related to hardware installation? or is it something from the LabVIEW software or the way I setup this? I used DAQassist for the input.
(3,386 Views)
That is a really close look at your data. Did you happen to notice the scale on the Y axis? You are in the E-6 range.
Tim
GHSP
(3,376 Views)
Yes, I just want to know if this is normal or if its an acceptable range
(3,364 Views)
Accepted by askhassan
Yes that would be a pretty clean signal.
Tim
GHSP
(3,358 Views)
