Noise from Strain Gauge Reading
Hi, I am trying to get some data from a strain gauge using a quarter bridge setup through NI 9235. I am getting this noise shown in the attached picture. Is it something related to hardware installation? or is it something from the LabVIEW software or the way I setup this? I used DAQassist for the input.
(3,381 Views)
That is a really close look at your data. Did you happen to notice the scale on the Y axis? You are in the E-6 range.
Tim
GHSP
(3,371 Views)
Yes, I just want to know if this is normal or if its an acceptable range
(3,359 Views)
Accepted by topic author askhassan
Yes that would be a pretty clean signal.
Tim
GHSP
(3,353 Views)
