Non-ActiveX COM Interface?
I actually have not been able to make it work with anything in LabVIEW. How did you make it work with the .NET constructor?
Claire Reid
Message 11 of 14
(864 Views)
I just placed a constructor node, then browsed for the file RPI_IOBoard.dll and selected the IOBoard() constructor (see attached image).  If that doesn't appear, you can try running the full installer if you'd like.  This isn't terribly critical though.
Ramirez Kleinigger Consulting, LLC
http://www.thinkrkc.com/
Message 12 of 14
(855 Views)
This is so interesting, because I did download the whole installer, and when I browse to the RPI_IOBoard.dll, it says "this assembly contains no active controls".
Claire Reid
Message 13 of 14
(848 Views)
I spoke to soon! I was using the wrong node!!
Claire Reid
Message 14 of 14
(846 Views)
