Non NI-DAQ device question
So I have an isolated constant voltage stimulator ( DS2A model) and want to use labview program to control signals coming from the stimulator but all I can find online are descriptions about NI-DAQ devices so I'm just wondering can I use my device, connected by BNC/USB cable as a DAQ device?
(2,656 Views)
The NI DAQ drivers (DAQmx and traditional DAQ) will only work with NI devices as far as I know.  Check with the device manufacturer to see if they have a LabVIEW driver for the device.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(2,653 Views)
BNC/USB does not make any sense. Do you mean a USB connection to the pc and a BNC signal connection?
As already mentioned, you should contact the vendor (which you have not provided). A USB connection can be of several different classes so if there is not a provided driver, the difficulty in communicating to it will be dependent on the class and how well the communication is documented. Your search for any sort of descriptions has to start at the vendor.
(2,618 Views)
