smartec UTI measurment
hello all.
now i am in over my head again. seems the lm35dz sensor is not accurate enough for my use so i went ahead and bought some smartec UTI dil-16 chips. combined with 3wire shielded pt100
and i find myself reading the datasheet over and over again but i cant quite seem to get it. http://www.smartec.nl/pdf/DSUTI.pdf
i have made the conections as in figure 9 example b and i belive it to be correct but...
and how am i to measure the temperature in labview ?
running an arduino mega by the way
hope some of you have the time to look at it 🙂
(2,955 Views)
No takers? I dont need a finished solution just an explanation because now im just confused 🙂
How am i to measure the signal and convert it to c`?
(2,815 Views)
It seems you are trying to connect a sensor to an arduino. What does that have to do with LabVIEW? Sounds like you need to find an arduino forum.
(2,790 Views)
