Not able to write value in a class from different VI
Situation is like this.
I have a main VI which calls a object manager which loads classes in an array of classes.
Back in the main I call a abstract method of the loaded class(To More Specific Class), then when the loaded class is executed it will write a value.
This all works, but when I perform the last step in a different vi(which is called from the main) then the loaded vi will not write a value.
The inheritance of the classes are:
- instrument
- abstract
- Sine(Here I try to write a value in the variable off the .ctl of this class)
(2,801 Views)
Accepted by InspectorGadget123123
Are you passing the object out of your subVI?  Remember that LabVIEW deals with objects in a by-value paradym.
GCentral
(2,793 Views)
Still learning how the classes work.
First I thought that every class created it's own variables and methodes, so when using 2 classes of the same, they are independent to each other.
But I now believe that the methodes are the same, only the variables change, correct me if I'm wrong.
You gave some good hints.
After the variables change I replaced the class in the class array(I created this function in my 'ObjectManager').
Now it works!
thanks.
(2,752 Views)
Yes, the methods are the same for every object of the same class and any children that did not override said method.
The main thing to remember is that LabVIEW is a data flow language.  So the data is in the wire.
GCentral
(2,733 Views)
