 sandeep2009.198
			sandeep2009.19809-19-2016 01:38 AM
Hello Shane,
I am communicating USB device which is customized device having SH2A Renesas Microcontroller with segger USB HID Device stack type is interrupt.Raw USB detected in NI VISA while reading the data from device i got an error " Unable to start operation because set up is invalid(due to attributes being set to an incosistant state).Please help me out to solve this error in read and write operation.error is attached.
09-19-2016 11:09 AM
The IDN request is not a HID request. Why are you trying to issue a T&M request to a HID device?
 sandeep2009.198
			sandeep2009.19809-20-2016 01:30 AM
Thanks for respond, if i sent controller command also i got same error.i need write and read operation through USB. if i used get interrupt vi i m getting timeout error.please help me out to achieve write and read operation.
 rolfk
			rolfk
			09-20-2016 01:49 AM - edited 09-20-2016 01:51 AM
If your device is a HID device you'll have to implement the HID protocol on top of USB raw. That's a considerably lower level protocol than the T&M protocol used to control for instance USB oscilloscopes, who would have understood your "IDN?" query. HID is normally fully binary and what needs to be sent in the data messages will be very specific to your device. I'm pretty sure it could be done through VISA but in the past I directly called into the Windows Setup and device driver API to access HID devices.
And helping you with your specific device will be pretty hard, since we do not have that device here with us and you do apparently need quite a bit more assistence with this than a few quick tips. I would search for alternative solutions in your case, or hire someone who has the knowledge to make this work.
09-20-2016 02:34 AM
Firstly, which commands do you need to be able to send and receive? You must have documentation somewhere about your device, right?
If you don't know this, then either find out or give up because each device can implement its own commands beyond the standard ones supported by the device class it belongs to (HID). Devices which belong to one class will not (except for VERY rare cases) understand anything about commands from different device classes. So make yourself familiar with what a HID even is (Documentation can be found on www.usb.org) before trying to do anything else. If the documentation is too complicated, then please find someone else who can help you with this specific device of just use the OS-support for HIDs.
I fear you have not done the basic level of research in trying to uderstand what a HID even is because your attempt to send a Test and Measurement device command shows that you are not yet familiar with the different classes of USB devices. Without this knowledge, you will not make any progress. It's a steep learning curve.
 sandeep2009.198
			sandeep2009.19809-20-2016 05:00 AM
Thank you..i m sending wrong command due to that it was showing error.i have to send in hexadecimal format.problem solved .device reading properly..
