Number in Hex and add 30h
Hi all,
how can i change a number in a hex-format and add 30hex that i get the right ascii-charakter?
for example: number:17---->Hex:11------>+30h-------->=41h--------->"A"
Thanks all
Thomas
(4,542 Views)
You don't need to convertit to hex to add 0x30. That's just a matter of representation.
Check annexed vi.
Hope it helps,
Paulo
(4,529 Views)
No need to change anything : decimal, hex, ascii are all U8 numbers, only the display is different. See the attached vi, where the only conversion is the U8 to String (char) using a type cast function.
Chilly Charly    (aka CC)
(4,525 Views)
That question was already answered here but here it is again.
(4,520 Views)
Instead of converting to hex, use decimal numbers. 30hex=48decimal. Add 48 to your number.
(4,511 Views)
