Number of Data Points
I am working on an interface for an HP8722C using a GPIB connector. I have a lot of the functions working correctly but I have hit a roadblock when it comes to the number of points in the sweep. All of the points work great up to 401 then 801 and 1601 points gives me an error and crashes the whole system. I am thinking that it might be a timing issue, like it doesn't let the function finish plotting before trying to collect it. Is there a way to make it wait a little longer to collect the data, like insert a delay or something?
Message 1 of 11
(3,651 Views)
Are you using the project style driver or the plug and play one? I can't look at either but typically there is an OPC? query.
Message 2 of 11
(3,634 Views)
I actually just figured out I needed to add a timeout box before the spot that is causing an error and increase the timeout time.
Message 3 of 11
(3,628 Views)
Not very elegant to put a fixed delay.
Message 4 of 11
(3,624 Views)
It may not be elegant but it works. Smiley Happy
Message 5 of 11
(3,616 Views)
It works for the time being. You can easily run into the same problem of the number of points increases.
Message 6 of 11
(3,605 Views)
What do you recommend?
Message 7 of 11
(3,600 Views)
Answer the question about which driver you are using, please. Then check if it is using OPC? That stands for operation complete. See the programming manual for the description.
Message 8 of 11
(3,593 Views)
Plug and Play - not using OPC
Message 9 of 11
(3,587 Views)
You might want to check the project style driver.
Message 10 of 11
(3,582 Views)
