Numeric Control does not generate Value Changed Event on Return
Hi all,
I seem to have changed something on my LabVeiw 8.5.1 front panel which has stopped all of my Numeric Controls generating Value Changed Events when the Return or Enter key is pressed.  The Value Change Event only fires if you TAB from the control or mouse click somewhere else.
Can someone please tell me how to get the normal functionality back!
P
Message 1 of 11
(4,612 Views)
Did you have specific key navigation configured for the control(s)?
Message 2 of 11
(4,599 Views)
Hi smercurio,
No key navigation defined for any controls
P
Message 3 of 11
(4,596 Views)
you need to define a key navigation for the enter key.
R
Message 4 of 11
(4,588 Views)
Ray,
I just put together a little test VI and it generates Value Changed events on a Numeric control upon hitting Enter with no key navigation set.
toad,
Is it possible that your control was changed to an indicator?
Message 5 of 11
(4,585 Views)
Hi Johnsold,
On a numeric control, yes 🙂  Try it using a string control 😉
R
Message 6 of 11
(4,565 Views)
Do you have a filtering event for the enter key. For example placing the following code in a while loop would do what you observe.
... unless the string control is set to "limit to single line". 😄
Message Edited by altenbach on 07-12-2008 11:08 AM
Message 7 of 11
(4,554 Views)
I didn't think about that one 😮
LOL! 😉
That's something which is good to know..
Message Edited by JoeLabView on 07-12-2008 08:39 PM
Message 8 of 11
(4,541 Views)
Hi all,
Many thanks for your suggestions - but I'm still having no luck.
I'll try and reply to all of your points in one hit here:
johnsold : No the control is definitely a numeric control.
JoeLabView : I've tried adding new numeric and string controls(limited to single line) to the front panel, neither respond to Enter/Return value changes.
altenbach : I've got no filtering defined for any keys.
I'm sure it must be something to do with the front panel itself or some environment option.  I can copy the controls to a VI in a new project and they respond correctly with value changed events.
Best regards
P
Message 9 of 11
(4,509 Views)
When all fails....  maybe if you posted your code and we could have a look / run at it.
R
Message 10 of 11
(4,492 Views)
