run VI on web
Hi
I would run my application on a Web page. Someone can suggest any tutorial to realize it?
Vincenzo
Message 1 of 10
(4,203 Views)
This link [broken link removed 1/21/26; article no longer available] should help you.
Message 2 of 10
(4,192 Views)
Hi
I have used your link...but it don`t work, and on the browser it gives this message.
Forbidden
Access to the image of VI '.Electrolyser Monitoring System 1.2.1.vi' is forbidden.
Message Edited by enzo78 on 07-11-2008 07:06 AM
Message 3 of 10
(4,176 Views)
Could you please be more specific? Did you follow the instructions and where did it go wrong? It would be easier to help that way.
Message 4 of 10
(4,166 Views)
Yes,
I follow the instruction...
  • I enabled the Web Server Configuration (see the attached)
  • I created my executable
  • I Make a copy of the labview.ini file in the labview directory, and rename it "Electrolyser Monitoring System 1.2.1.ini"
  • I open <Electrolyser Monitoring System 1.2.1.ini> and change the first line, [LabVIEW], to [Electrolyser Monitoring System 1.2.1].(see the file attached)
  • I Make sure the file has the following entries in it:
    postScriptLevel2=False (I fill this line, because wasn`t in it)
    WebServer.Enabled=True (It was in it)
  • I Move <Electrolyser Monitoring System 1.2.1.ini>  to the same directory as the executable.
  • I Run the executable
  • I open the Web browser
    http://192.168.0.222:86/.monitor?Electrolyser%20Monitoring%20System%201.2.1.vi&refresh=300>
and it give me that message.
Message 5 of 10
(4,156 Views)
Ok,
Maybe you should use Tools->Web Publishing Tool instead. Just follow the procedure and you should have a html and an URL to test with. This way you shouldn't have to do any modifications to your *.ini file either. Remember to check that the Web server is still enabled and the port is free.
When trying to connect to your *.exe, first close Labview and after that run the executable. You should see <W> Server: localhost or something similar in the lower left corner in your executables window if the Web server started. Now try to connect to the given URL. Should work fine.
Message 6 of 10
(4,135 Views)
Hi
Thanks for the help, finaly my web page works. But I see on it a Grey background  on it as you can see in the attached image.
My application is smaller than the higher square. How can I fit the application with this square?
thanks
Vincenzo
Message 7 of 10
(4,108 Views)
You're welcome. Open your VI and select File -> VI Properties -> Windows Size -> Set to Current Panel Size and try again.
Message 8 of 10
(4,099 Views)
Already done.
When I run my application on my computer it works well see the attached, but when I realize a web control I have that problem.
Message 9 of 10
(4,096 Views)
Hmm, you could try to narrow down your window. Decrease the current width in the window size menu by the width of the vertical scroll bar and your screen will show as it should in your browser. In LabVIEW the window won't be fullsized.
Does anyone have a better solution to this?
Message 10 of 10
(4,074 Views)
