Numeric control over many orders of magnitude
@Dennis_Knutson wrote:
The values on a knob can be anything you want with text labels. The actual numeric value would not be displayed at all. The data type of the knob should be an integer.
Which will then be an enum, somehow.
Okay, got it, thanks for you answers 🙂
Best,
bastlwastl
Message 11 of 17
(1,507 Views)
NO, it will not be an enum! A knob with text values is not at all the same. You can have text values, for example ".1ms, 1ms, 10ms" and the actual values would be 0, 1, 2. Evenly spaced on the knob and not an enum.
Message 12 of 17
(1,492 Views)
Best,
bastlwastl
Sorry, you don't "get it".  Dennis is correct (as usual) -- the values can be whatever you define them to be (it makes sense to set them to be the same as the Label, but you don't have to ...).  Here's an example -- the Horiz Gain control is of type Dbl, and it is wired to a Dbl indicator (not an Enum).  When I run it with the dial set to 0.2, you'll see it return 0.2.  [Also note that you have great freedom in defining the labels -- notice I use "Ten" instead of 10.0, just for effect].
A good practice if you create a dial such as this is to go into its properties and set the Data Entry property with Min and Max set to your Dial's Min and Max values, and also set it to Coerce values to this range (just to be safe).
BS
Message 13 of 17
(1,489 Views)
@JÞB wrote:
Log Scale on the knob!
Ludicrous speed!
Bill
CLD
(Mid-Level minion.)
Message 14 of 17
(1,468 Views)
1, 2, 3, 5!
I know Bilko's luggage combo now!
go ahead- "give me the Raspberry>
Spoiler
Google "Spaceballs" and go all the way to plaidSmiley LOL
Message 15 of 17
(1,459 Views)
@JÞB wrote:
1, 2, 3, 5!
You skipped a number in the combination.  Funny, you don't look Druish.
Prepare to hit "Post".  Ready to hit "Post"...
GCentral
Message 16 of 17
(1,421 Views)
@bastlwastl wrote:
But then e.g. 2ms is possible if I use an increment of 1ms. But i wan't to restrict the values to 1, 10 and 100.  Or is the increment then logaritmic as well?
Use Logarithmic Mapping feature in th Knob control. Knob - Scale - Logarithmic Mapping.jpg
- Partha ( CLD until Oct 2027 🙂 )
Message 17 of 17
(1,389 Views)
