Numerical List Box to Boolean array
I have two listboxes. One of them has different frequences and the other one has difference voltages.
For each interation, one freq and one voltage should be seleted and the correspoding elements in the boolean array should be high.
Freq                   Voltage
100                        2
200  <                    4                                   ====>  0100 0010
300                        6 <
400                        8
Does anyone know how to do the convertion from numerical listboxes to the boolean array?
Thanks!
Message 1 of 9
(4,653 Views)
Accepted by tian66
Try this
Of course this assumes that the listboxes have exactly 4 elements each.
Message 2 of 9
(4,648 Views)
Thank you for your answer.
Actually there 5 frequecies and 8 output voltages.
But the the boolean array output is in an inner loop and the listboxes are outside of the inner loop.
How should I arrange these listboxes?
Message 3 of 9
(4,638 Views)
Thank you. I got it. Please ignore the previous reply.
Message 4 of 9
(4,634 Views)
I should have gone to Perdue...
They probably wouldn't have me 😄
Jim
Message 5 of 9
(4,627 Views)
Are you trying to get a honorable mention in the Rube Goldberg thread? 😄
(Also, the output is supposed to be a boolean array, not a U8 numeric.)
Message 6 of 9
(4,620 Views)
I found a problem for the listbox.
If the I just select two freq from the listbox, the indexes are always 1,2 but not 2,3.
How should I solve this problem because not all of the values in the listboxes will be selected.
Tianshu
Message 7 of 9
(4,610 Views)
Well, you did not tell us that you allow multiple selections. Still, it should be easy to modify my example. Can you attach some simplified code.
Message 8 of 9
(4,601 Views)
Try this:
Message 9 of 9
(4,599 Views)
