Numerical integration error
I am trying to compute the integral of 3x^2 in the range 0-1 with step 0.01 using the Numerical integration VI. I am getting a data mismatch error with the array output when I connect it to the VI. Why is that so? Thanks.
(4,161 Views)
your vi is in labview 2018, try to upload if any lower version vi.
i can't able to open your vi.
Please Refer to the 1D Explorer VI in the labview\examples\Mathematics\Optimization directory for an example of using the Integration VI.
I think this can solve your problem....
(4,147 Views)
Accepted by topic author dbhadra
Remove the "built array" after the FOR loop. (The auto-indexing output tunnels already makes you an array).
Maybe do a few tutorials first?
(4,139 Views)
thanks for the solution
(3,807 Views)
