OAT support - Slowroll errors
I want remove slowroll errors in my acquisitions but before this I need understand when uses OAT Get Vector Reference or OAT Get Even Angle Reference to get reference slowroll signal and combinate with OAT Compensate Even Angle Signal or OAT Compensate Vector Signal to remove the slowroll errors of acquisited signal.
The Order Analysis Toolkit Manual is very closed in explanation, i need more technical informations to decide that use. Thx for specialized help.
Leonardo de S. Cavadas
Maintenance Engineer and Inspection - Bureau Veritas do Brasil
Engineer Metallurgist with emphasis in Advanced Materials
Technologist in Computer Science
(2,797 Views)
look at in these links that it contains important information on Order Analysis Toolkit http://zone.ni.com/devzone/cda/tut/p/id/3575 http://zone.ni.com/devzone/cda/tut/p/id/3779
(2,751 Views)
