Is there a Driver for Lab View 8.0 for IXIA 400 / 400T ?
Hi to you all
I am searching for a Lab View Driver for a IXIA 400 / 400T, or if there isn’t any than the commands for remote control over the IXIA 400 / 400T
I have the user manual and it has there the c++ commands, can I use them as remote commands for the IXIA ?
(3,122 Views)
There's no drivers for that in the NI Instrument Driver network, and the company's web site doesn't seem to have anything, though this is not that big of a surprise. Given that it has C++ commands it's quite likely it's calling functions in a DLL. If that's the case, you can create LabVIEW wrapper functions for the DLL functions. Can you tell if it's using a DLL? This information would likely be in a programming sub-manual, or a section in the user manual dealing with programming. Given the type of device it's also possible that it might just be talking to it directly via TCP/IP. Can you provide a code snippet that is in the manual, or a link to the manual?
(3,110 Views)
