problem in filter
I try to test filter.vi. I generate a noise signal and feed into filter. It always show freqency problem. I understand there is a restriction with sampling rate and sampling number. But I could not figure it out. Please take a look at my vi.
Thanks a Lot
(2,827 Views)
You've made a couple of fundamental mistakes. First, you have pass parameters to the noise function that does not generate an error. The -1 for a mean created an error and there was no output. Second, you need to create a waveform data type before you wire the noise output to the filter. Make the mods as shown below and see if you get what you expect.
Message Edited by Dennis Knutson on 09-26-2007 08:24 AM
(2,817 Views)
