OCR Creation
Dear sir's,
i'm facing issue to creation of OCR in Fuse Box. we are using vision assistant. but unable to solve Purpose.
kindly Suggest.
(2,332 Views)
Accepted by Sachin981
Hello Sachin981,
Share us what you have done using Vision Assistant (Image Process technique) to extract Character / to train the .abc file.
based on your work we can support you on next stages.
I am guessing you are trying to extract and Validate Numbers in Fuse Box (something like 5/10/30)
(2,328 Views)
Hello Palanivel,
Thanks for Reply.
yes i'm Extracting Characters. Please find Attached File of a 3 example fuse set file.
(2,278 Views)
