OCR Creation
Dear sir's,
i'm facing issue to creation of OCR in Fuse Box. we are using vision assistant. but unable to solve Purpose.
kindly Suggest.
(2,318 Views)
Accepted by topic author Sachin981
Hello Sachin981,
Share us what you have done using Vision Assistant (Image Process technique) to extract Character / to train the .abc file.
based on your work we can support you on next stages.
I am guessing you are trying to extract and Validate Numbers in Fuse Box (something like 5/10/30)
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,314 Views)
Hello Palanivel,
Thanks for Reply.
yes i'm Extracting Characters. Please find Attached File of a 3 example fuse set file.
(2,264 Views)
