02-07-2011 03:37 PM
I am using NI 9215 for acquiring millivolt data coming out of LEM voltage and current sensors( referenced to the power supply ground). There are 6 sensors and so 4 channels of one mod+ 2 channels of another mode of NI 9215 is used. I have connected the signal(ac) to the positive or A1+etc and negative to the power supply ground. I have also connected this ground to the COM terminal of the module. FPGA DMA FIFo based data transfer is what I am adopting. But in RT Vi I get alot of "cross-talking!!". ie: one channel of data mixes up with another channel data!! I disconnected the ground from COM terminal, still not working. Why this is happening? Can anyone help me bit on this....
02-08-2011 04:01 PM
Hi
if i understand you description: 6 voltage channels ? Assuming that is the case,then you must be measuring the volt drop over resistors in the current sensor circuitry.
If you have coupled all negative sense signals to the negative power supply then yes you could have cross talk. In whcih case necessary to
adapt you hardware sensing solution, which could mean utisling a different type of senor module.
What frequency are you wanting to measure? 9205 module has a better resolution than 9215 but is a mux not sim.
Could you coding have an interference on the signal analysis?
xseadog
02-09-2011 12:17 AM
02-09-2011 01:24 AM
Don't shout![]()
xseadog
02-09-2011 01:32 AM
Hey
suggest you provide salient information.
What actual terminals are connect ( name them etc)
Very difficult to help you in the dark.
Are we in the ether?
Are your primary signals 4-20 mA?
xseadog
02-09-2011 01:33 AM
No! i am not shouting ![]()
the font size became large and i accidently posted it ... so I am agin posting it:
Also, is it possible to combine two modules of 9215 and give it directly to one FIFO, because here we may have to deal with different conversion times....since I am using 4 channel from one and two from the other one...
Jeeva
02-09-2011 03:13 AM
Hi
You are still shouting drop the bold font![]()
have you checked out the waveform ref example?
http://zone.ni.com/devzone/cda/epd/p/id/6206
If you have 2 different conversion times then you will need to change you architecture!
Suggest 1 , if using 2 different sampling rates then use 2 FIFO.
Suggest 2, if 2nd sampling rate is disivible by first then us buffering ring.
PS
if you don't answer the questions then dont't expect help![]()
Questions are asked to determine what you are attempting to achieve, and what you have managed.
xseadog
02-09-2011 03:14 AM
Hi...
I am not measuring currents driectly. here I am measuring the equivalent voltage(across a resistor) and is interfaced with 9215. Also the currents across the resisitor are small in terms of ma(it can go upto say 0.03A). Here I am sensing the equivalent voltages and that is why I am interfacing with 9215. I hope I am somewhat clear now b :manhappy:
02-09-2011 03:34 AM
I will try what you suggested. Also its first time I am using this discussion forum. Therefore I apologize if I had posted something crazy or if I am not so clear ! and I also would like to say that the large sized font/bold etc accidently happened and was not intentional.... I am not an advanced user, so my intention is to learn something and to solve some issues .
To make it more clear :
A10+ : signal((AC range is 0 to max +/- 2V)
A10- : Ground of the power supply
This is the config for all the 4 channels ie upto A13-.
From the second module of 9215, I am using A10+, A10-,A11+ and A11-. All 6 I am interfacing to a DMA FIFO.
Pin 8 is NC and pin 9 is COM. Pin 9 is connected to ground. ie: to A10- itself.Ground of the power supply.
The rest I had already expalied and I will try what you have suggeted and will get back.
02-09-2011 03:39 AM
You may think your answers are correct.
There are from where you stand!
However i am non the wiser! provide screen dump of your physical electrical connections.
Also screen dump of your code (FPGA, & project )
xseadog
