OOP Success Package
Is there any OOP success Package Like CLD success package?
After learning basic  fundamental from various  webcast and  white tutorial, it require  some  good example  which are combination of OOP+State machine or OOP + Producer consumer  OR QMH to get idea how to implement OOP in programming.
This kind of example  will  help to  switch coding perceptive   from   Sequential coding to  object based coding.
 Nisarg Shah
Message 1 of 12
(4,704 Views)
There is an online training for OOP, it requires active licence.
But if you want to use OOP approach for CLD exam, it is just an overkill. A simple state machine most of the time will help you to succeed (and document properly). You can get more dedicated help and info at the cert forum board:
https://forums.ni.com/t5/Certification/bd-p/Certification
Message 2 of 12
(4,673 Views)
I am not  aiming to use OOP for CLD EXAM. I am CLD.
I am aiming to learn this  concept  for  intermediate to advance  application development and Of course, to achieve next level of CLA  next year.Smiley Happy
Message 3 of 12
(4,667 Views)
I did not find the online OOP training real useful, and I got the info that NI is not planning to update/enhance this course. Anyway, here you can access it if you own an active LV licence: http://sine.ni.com/tacs/app/overview/p/ap/of/lang/en/pg/1/sn/n5:selfpacedonline,n24:14963/id/1587/
Message 4 of 12
(4,659 Views)
I had gone through this online training with my active licence. Even I also did not find  this training real useful.  That is the reason i  am looking for some  S.O.L.I.D  example which can fill the gap.
Message 5 of 12
(4,653 Views)
Well, good luck then. I only managed to find "fragments" so far...
Message 6 of 12
(4,647 Views)
I know there are some videos floating around for Actor Framework training, which is an OOP heavy Queued Message Handler.
But you might want to look here: LabVIEW Object Oriented Programming Resource Directory.  I know there is another resource that is well put together by Elijah Kerry, but I am not finding it in the 2 minutes I have right now.
GCentral
Message 7 of 12
(4,607 Views)
Message 8 of 12
(4,599 Views)
Accepted by Nisarg
@Nisarg wrote:
Object Oriented Design Patterns Technical Manual and Exercises
No.  But it has a link to the one I was thinking about: Applying Common Object-Oriented (OO) Design Patterns to LabVIEW
GCentral
Message 9 of 12
(4,588 Views)
Good resources  with examples and  explanation.
Thanks..
Message 10 of 12
(4,578 Views)
