OPC SERVER
Hi.
Because when I do an OPC server and I want to link the variables I get a message"Program stopped working" and closes all
I hope your help and thank you very much.
(3,107 Views)
Are you using "Windows Server editions"??
Thanks as kudos only:)
(3,092 Views)
Hi Danil33.
if I am using the following server .
(3,076 Views)
This is a bug. You can create connection to server than save everything, exit labview, open saved project and add variables.
Try it.
_________________________
Rookie; LV 2011 on WIN 7
(3,057 Views)
