OPC UA Client
I search an OPC UA Client for TestStand 2012. I have downloaded the DSC-Module for LabVIEW 2012 for evaluation. Now I have tested the OPC UA Client with three OPC UA Servers, but only with one works the communication.
1.) OPC UA Server from my company (in development) -> Error code -356617 (Screenshots OPC_Client/Server_1)
2.) Softing OPC UA Demo Server -> Error code -356605 (Screenshots OPC_Client/Server_2)
3.) Unified Automation UD Demo Server -> works (Screenshots OPC_Client_3)
What could be the reason? Thank you for your help.
Regards, Sven
(5,504 Views)
Accepted by Icebaer
the result was that LabVIEW / DSC <= 2014 has connection problems without Security Mode. The Support told me that with LabVIEW / DSC 2015 this problem will be solved.
Sven
(5,225 Views)
ok now we try with Labview 2015 and connect as OPCUA Client to an CODESYS V3 OPCUA Server.
Anyone know how to setup the browse path here?
(4,981 Views)
CDSUA : Do you reply correct topic @@?
(4,976 Views)
probably, sorry not but i did not find the correct entry point to do this / start the post?
(4,966 Views)
I am encountering the same problem. Were you able to find a solution to the path?
(2,865 Views)
