OPC UA Toolkit Support for Labview 64 BIT ??
Hello Everyone.
I confused over OPC UA Toolkit Support for Labview 64 Bit .
following link shows it support Windows 64 bit os using 64 software (Labview)
https://www.ni.com/en/shop/software-portfolio/national-instruments-product-compatibility-for-microso...
and other one shows it dosent support.
https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil...
I want to use OPC UA Toolkit with Labview 64 Bit please guide me.
Thank you.
(3,835 Views)
Did you notice that the one which states that it is supported is for Windows 10 while the other is for Windows 7?
And you seem to need the 2018 version of it for 64 bit support.
So what has likely happened is that NI released the 64-bit version with LabVIEW 2018 and since it is 64-bit, decided to NOT test it on Windows 7 at all. There might be technical reasons that it can not work with Windows 7, but it can be also just that they limited the testing effort to not test on old (almost obsolete) OSes, given that 64-bit versions of LabVIEW are still fairly seldom used in the wild.
Rolf Kalbermatter  My Blog
(3,800 Views)
Will it Support Labview 2017 64 Bit with Windows 10 64 Bit ?
(3,792 Views)
You can try but probably not! That list states the minimum version that NI has tested and if it is a lower version it will usually not work. Actually it might, but it is generally tricky to impossible to convince the installer to put the necessary files in the lower versions of LabVIEW.
(3,783 Views)
hey rolfk Thanks for your reply.
OPC UA  dosent support official installation for labview 2017 64 bit.
i am unable to find out version 18 from where should i get it ?
any better possible way out ?
(3,753 Views)
Accepted by AtulS
labview 2018 available and OPC UA toolkit is supported for 64 BIT
(3,467 Views)
