OPC UA with LDS in Labview 2017
I am working with the OPC UA LDS in Labview 2017 and am not getting the OPC UA server and Local Discover Server (LDS) to trust each other. I follow the NI documentation ("How Do I Make an OPC UA Server and the UA Local Discovery Server Trust Each Other?") and when I get to the "Console Root "Certificates (Local Computer) "UA Applications "Certificates" the UA Applications folder does not appear to me.
Note: the image is in Portuguese because my Operting System is in Portuguese.
I have installed the LDS and it is active
I'm not finding a solution to the problem and I also have NI OPC Servers 2016 installed.
Any suggestion?
(2,458 Views)
HI,just wonder did you solve this, I met the same problem.
(782 Views)
