OPC URL features
Hello
Can any one please explain this OPC URL (what each part mean?)
opc://localhost/Tunneller:ric841x1:osi.da.1\\\ric841x1\66TI1450
I do not understand these parts “Tunneller:ric841x1:osi.da.1” and “\\\ric841x1\66TI1450
Please let we know if there is a link for more advance tricks for OPC URL
I am getting this error:
1/22/2007        10:41:34 AM   Err Code:         -1967259646   Source:DataSocket Connect.vi
Error: Parsing URL.<ERR>      Addtl Txt: Multiple OPC Items Monitor
Let me know if you know what error is this
Thank you
Amit
(5,625 Views)
Hello
Sorry about the smile faces. I did not know how do thery get there.
But basically it is Tunneller:ric841x1.osi.da.1
and Source DataSocket Connect.vi
I just want to know that can I use two user in the OPC URL, with two back slash to separate user name.
Thank
(5,615 Views)
Hi Amit,
I don't completely understand what you mean by "I just want to know that can I use two user in the OPC URL, with two back slash to separate user name."
In any case what you are seeing looks like the complete address to an OPC item from an OPC server.  "Tunneller:ric841x1.osi.da.1" is the name of the OPC server, "ric841x1" is most likely a folder within this particular process for organizational purposes, and "66TI1450" would be an individual register or data item.
To really know what this means you will need to consult the documentation for this OPC server and/or the documentation of the PLC/hardware it connects to.
The DataSocket Select URL VI allows you to browse for OPC servers on your machine and browse them.
Doug M
Applications Engineer
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(5,608 Views)
Not exactly your fault - : D is turned into Smiley Very Happy and : O is turned into Smiley Surprised
___________________
Try to take over the world!
(5,596 Views)
Hello Doug
First of all, thank you for your information on OPC URL.
Actually, this is first time I am using OPC with LabView, and I am looking older application which has OPC URL. I wanted to understand how OPC URL address works.
By reading some document I understand some part of the URL but not fully.
You have explained very clearly what I am looking for.
"Tunneller:ric841x1.osi.da.1" is the name of the OPC server ( I am confuse with colon ‘:’ and point ‘.’)
“ric841x1" is most likely a folder within this particular process for organizational purposes
Again great help, thank you for that.
Amit
(5,594 Views)
Thank you TST
I thought that, there is some thing wrong with my Internet Explorer.
I also know some trick to create funny face.
Amit
(5,590 Views)
Amit,
No problem 🙂
Doug M
(5,581 Views)
