[OT] Ethernet based serial interface hardware suggestions
How do you unmark a solution on a post? I hit the wrong button and marked the previous post as a solution.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 13
(418 Views)
"Options" drop down near the top right has a "Not the solution" thingy.
Ben
Message 12 of 13
(415 Views)
@Ben wrote:
@JÞB wrote:
I thought the omega controllers had a direct ethernet interface is this not an option there.
That would simply the design greatly.   Your app could even be a web service.
That depends on the millennium in which they were built. Smiley Wink
I will be visiting them tomorrow and poking around in the cabinet to find out what I am really dealing with.
Ben
Well,  that sounds a lot like a potential "Value add" change to the SOW:D
the client should be delighted that such a knowledgeable person will be poking around.
No charge brother
Message 13 of 13
(404 Views)
