Obtain all properties from property node
IT is called Traverse for GObjects.vi, under Traverse.lvlib
Message 11 of 12
(1,045 Views)
That is a Traverse for GObjects.vi. It is configured to programmatically change an object in the block diagram. Typically after the code you posted there is a bunch of property nodes calling the properties to be changed.
Message 12 of 12
(904 Views)
