11-21-2011 08:17 AM
Does anyone else have the same luck as me, where you scratch you head for a good part of the week then it all comes together in the last hour of the week on Friday? This seems to work quite well.
11-21-2011 08:19 AM
By the way, thanks Ben64 for your help. It was much appreciated.
--Brian
11-21-2011 02:48 PM
well..sometimes things seem perfect that they are just a bit off. Here is where I am now.
With the code below, the 0th conrol coming out of the panel property node is the tab control that I want to access. Can I use some NI vi to select the 0th item in the array from "controls[]" and wire it to the input of the Pages on the Tab Control?
11-21-2011 03:14 PM
